Hi Olaf,
Is there a possibility to purchase a fully assembled Icarus for the Qidi x-max.
I live in the UK.
Hi Olaf,
I live in the UK.
Except USA now worldwide delivery possible. With the following exceptions/extras/comments:
Just for the case somebody want to see:
The (my) first fully assembled Tweacarus Mod ->
I'm sure this will sound like a paid promotional post right away. But it is not. Really!
I upgraded my Qidi X-Plus from the standard hotend to the Icarus mod about three weeks ago.
Before the upgrade, I was about to sell my Qidi in frustration. Almost every print had problems with the extruder or clogs in the hotend. It was really scary.
In the 3 weeks with the Icarus upgrade, I haven't had a single messed up print. In the meantime I have printed 1kg PC-FR, 750g ASA, half a roll of TPU and 1,5 rolls of PLA. The Qidi had enough opportunities to cause problems. But instead, with your upgrade, it prints so brilliantly that I would never want to trade it in for another.
humebeam, @Olaf:
I just wanted to say thanks for the great job in inventing the hotend design and for the great service in pre-assembling the carriage.
Music to our ears, thanks Jens!
Update November 24, 2021
New belt tensioner: The new Icarus belt tensioner for open belts has been tested now for a few weeks with no issues. It is compatible with the current version of Icarus so there is no need for a reprint, the same carriage is used for both stock (closed) belts and open belts. If you're looking to replace your belts and pulleys to “industry standard” GT2 this should be happy news.
The tensioner needs an M3 heated insert installed and the belt peg a 30 mm M3 socket head through it, I will not cover this in the assembly guide, it should be pretty self explanatory. These parts are already included in the BOM.
Meanwhile, the actual belt peg was refreshed and the new version has a hole for the socket head, this hole can just be ignored if you use a stock (closed) belt.
https://www.prusaprinters.org/prints/81744-i…ter-15-dragon-m
Moin Olaf,
wann glaubst du hast du wieder einen Icarus zum bestellen fertig ;-)?
Viele Grüße und schönes Restwochenende!
Hi Daraun
nächste Woche werde ich wieder einen freischalten. Die sind dann ja noch nicht fertig - ist eher so, dass ich dann meine innerhalb von 10Tagen liefern zu können. D.h. Teile sind alle da und ich habe wenn nix dazwischenkommt Zeit zum bauen.
Olaf
Ah sehr cool - dann wird einer geordert nächste Woche :-)!
Tweacarus läuft übrigens super, bisher habe ich PLA+ und TPU gedruckt, geht ohne dass ich irgendwelche Slicereinstellungen gegenüber dem Hercules Mod geändert hätte.
Momentan grübele ich schon wieder, ob man nicht aus akustischen Gründen die Drehzahl des 4020 Lüfters senken könnte da er ja ohnehin mehr wie der Standard leistet, und dieser reicht ja auch.
Hallo und guten Abend,
Ich habe seit einem Monat einen Qidi X-Plus und habe vor meinen Drucker zu modifizieren. Evtl. mit einem neuen Extruder. Was hat dieser Extruder für Vorteile gegenüber dem Standartextruder. Seit doch bitte mal so nett und klärt mich hier mal auf.
Was muss ich alles ändern, wenn ich so einen Icarus Extruder verwenden möchte?
Gibt es noch andere Alternativen als den Icarus?
Noch eine Frage, auch wenn es hier nicht reinpasst. Gibt es die Möglichkeit die Treiber beim X-Plus zu tauschen? Meine sind ziemlich laut.
Vielen Dank und noch einen schönen Rest 1. Advent
Gruß, Falco
Moin Falco und Danke für den ersten Beitrag
Was ändern:
Nicht wirklich viel - alten Extruder entfernen neuen aufklipsen und ein paar Firmwareeinstellungen. Steht alles sehr detailiert hier: Qidi Extruder Upgrade - Icarus Mod
Vorteile:
Der Hauptvorteil: Er funktioniert deutlich zuverlässiger mit mehr Materialien (Extrudervortrieb und Verstopfungen). Am Anfang lief mein Qidi auch OK bis ich angefangen habe verschiedene Filamente zu probieren - am Ende hatte ich 5 Extruder von Qidi und alle immer wieder dicht. Seit Wechsel auch Chad/Herkules nun Ikarus nur durch mein Versagen mal ein verstopftes Hotend.
Auch wichtig: Richtiges Vollmetall hotend für höhere Temperaturen (die Qidi Hotends geben bei >250Grad recht schnell auf).
Alternativen: Herkules wenn man BMG Extruder nutzen möchte z.B. für klassische V6 Hotends.
Treiber: nicht das ich wüßte? Laut echt? Also bei mir übertönen die Lüfter (obwohl schon leisere drin sind) die Treiber bei weitem.
Stimmt Advent ist ja schon EUCH ALLE auch einen schönen ersten Advent!!
Hallo Olaf,
vielen Dank für deine schnelle Antwort.
Ich drucke hauptsächlich PETG oder ASA und ABS, also Konstruktionsteile. Welchen Extruder kannst du da empfehlen? Den Ikarus oder den Herkules? Kannst du mir vielleicht den Unterschied der beiden kurz erklären? Wie sieht es mit der Druckgeschwindigkeit bei beiden Extrudern aus? Kann man damit auch etwas schneller als mit den Standartextrudern drucken? Falls ich mich für den Ikarus entscheide, welche Ersatznozzel benötige ich dafür?
Den Umbau traue ich mir schon zu. Ein Backup habe ich für die Kalibrierung des normalen Extruder schon mal gemacht. Kein Problem. Das mit den G-Codes bekomme ich auch schon hin. Das Pid Tuning würde ich schon gerne mit Octoprint durchführen, nur wie bekomme ich die Verbindung zum Drucker? Dann muss ich es wohl doch mit dem USB Stick durchführen. Aber sollte auch hinhauen.
Also nochmal zum Anfang. Welchen würdest du mir empfehlen, was soll das komplete Teil dann kosten und wie lange sind die Lieferzeiten?
Vielen Dank schon mal im Voraus
Gruß Falco
Octoprint
bzw
Qidi X-Max X-Plus / X-Max mit OctoPrint
Preis: https://www.elektrifiziert.net/shop/
Lieferzeit: steht aber paar post weiter oben RE: Qidi Extruder Upgrade Icarus Mod
ich baue wenn ich Zeit habe - aktuelle Lieferzeit 2-3 Wochen - also zumindest vor Weihnachten.
Sodele die Bestellungen von letzter Woche sind fertig gebaut. Funktionstest gibt es vermutlich heute Abend noch, dann können die auf jeden Fall diese Woche noch raus.
Ich warte noch auf eine Lieferung Orbiter wenn die da ist, stelle ich wieder ein paar Stück in den Shop ein.
Ole
wuhuu - kann es kaum abwarten zu bestellen
Hallo Olaf,
ich würde mich da jetzt mal reinklinken und auch einen kompletten Satz Ikarus bei Dir vorbestellen.
Gruß, Falco
Sodele - die Orbiter kamen heute an. war eigentlich erst für Montag anvisiert aber gut auch mal etwas was schneller geht.
==> Shop wieder freigeschaltet.
Hmmm, vielleicht sollte ich 2 X-Plus zusammenlöten und nen IDEX draus machen
