Earlier versions of the mount not affected, just the one from yesterday.
humebeam Still printing, but I think this corner should be edited for printability. At least without cooling this corner is not working very well.
Maybe I should open an Ikarus thread... I will pushlish some further comments while building - have already some questions comming up.
Please do
I will take a look at the corner. I have not had any issues printing it though, think I have six or seven prototypes printed. You mean where the supports are placed?
Actually there is a slight overheat on a couple of carriages now that I look. In will post a fix shortly with the corner cut at 45 degrees.
yes - without cooling you get the following (this was printed wo support as well). First time I used the Prusa Orange PC
Icarus 1.13 posted, only change is the problematic corner above is fixed.
Tried it yet?
No - as always lacking time - I am currently printing a lot with my Qidi if spool is almost empty I will try.
Ich habe definitiv interesse an dem Ding
EDIT: Falls du es für deine Planung brauchst : Die X-Plus Version
Nächster testprint in ASA Blau (marke keine Ahnung):
Die Schräge (war vorher gerade) ab 1.1.3 lässt sich jetzt gut drucken. Ich hatte noch support unter dem flachen teil und beim entfernen ist mir der PCB Halter abgebrochen. Ich drucke jetz mal ohne support, mal schauen wie das in die Luft drucken funktioniert. Bei PC ist der Support an der Stelle def. einfacher zu entfernen gewesen, hier war es recht gut verbacken.
Gut: Ringing ist weg nach meiner Inputshaperoptimierung.
Yes it is a bit thinner there than Hercules because of the opening for the 4010 fan but I haven't managed to break any, not even with my ABS test print
I seriously doubt you will have issues at that area with one printed in PC. Still, I'll see if I can reinforce it a little, I'll take a look tonight.
Was not a complain and I was not careful at all - test how stable it is - destroying it was an expected result.... But getting it even stronger would of cause be great.
Don't worry, I don't see any of the feedback as complaints but rather as good info on what to improve, there is always something
Yes
Question: Why don't you place the PCB Holder behind the Fan?
When it's tilted it fit with the flat cable holder and give space for the hotend Fan.
Yes
You mean behind the blower fan?
Hallo,
Was spricht dagegen den Halter aus ASA zu drucken?
Hat PC soviel mehr Vorteile ?
Mit freundlichen Grüßen
Yes. Basically like on the original Extruder, but between Extruder and blower fan.
And because you want to lift up the flat cable a bit you may tilt the PCB a few degrees.
Advantage is also that the cable will not be twisted so much.
spricht nix dagegen. PC ist eben deutlich steifer und verformt sich bei Hitze weniger schnell. Ich nutze aber eigentlich immer PC-FR. FR steht für selbstverlöschend. Finde ich um das Hotend herum einfach sicherer.
