Hier noch das mail von Qidi (Linda) vom 15. Februar 2023, wurde erfolgreich installiert, nachdem der dual gear extruder von Qidi eingebaut wurde. Soweit alles gut
Thank you for your reply.
Below is the video for replacing carriage and ribbon cable.
https://drive.google.com/file/d/1cz60HA…iew?usp=sharing. Remove
https://drive.google.com/file/d/1Cpnj8g…iew?usp=sharing. install
Then please check below steps to update the firmware.
01. Save attached file into USB pen drive, please save 3 files to ROOT DIRECTORY, then please check below steps to print the file i mentioned.
02. Turn on the printer, plug the USB pen drive on.
1.print the "update.qd"file. It will restart the screen and makes " di`di`di" sound.
2.print the "[Qidi-Max2]V2.31-UI.bin" file
3.print the "[Qidi-Max2]V2.31-参数.gcode” file
After you print 3 files, the updating will be done.
It is normal to show " machine parameter error" when you print the first file, please print the remaining two files to finish the update.
Please reboot the printer by back power switch , level the platform to print.
Thanks
Linda
