Qidi X-Plus Corner Mount Brackets
  • As a part of my project to port over the Qidi X-Plus to my TronXY X5SA, I couldn't find the OEM corner mounting brackets anywhere (I searched VERY hard on the interwebs). Qidi was nice enough to send me 4 brackets where I measured thoroughly with my digital calipers and designed it onOnShape.
    The slight differences here are the structure rafts on each side are no longer there, and the 10mm linear rod spot being a few mm off (1.5 vs 2mm OEM). The mounting holes are now 5mm bolts, rather than the 2mm bolts. I've included the 2mm bolt version if you prefer.
    Note: The 2mm bolt version requires threaded inserts.
    If you enjoy this build, please consider downloading, liking, and following for future updates.
    Print: PETG, 30%
    Qidi X-Plus X-Max corner mounting bracket by BTCB | Download free STL model | Printables.com
    Corner bracket for the Linear Gantry Rods | Download free 3D printable STL models
    www.printables.com
  • BTCB October 7, 2024 at 6:08 AM
    Changed the title of the thread from “Qidi Corner Mount Brackets” to “Qidi X-Plus Corner Mount Brackets”.
