Install TimescaleDB on Ubuntu
    apt install postgresql
    sh /usr/share/postgresql-common/pgdg/apt.postgresql.org.sh
    Add repo for timescale
    sudo sh -c "echo 'deb [signed-by=/usr/share/keyrings/timescale.keyring] https://packagecloud.io/timescale/timescaledb/ubuntu/ $(lsb_release -c -s) main' > /etc/apt/sources.list.d/timescaledb.list"
    wget --quiet -O - https://packagecloud.io/timescale/timescaledb/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/timescale.keyring
    Install timescale itself (check which version you are running using psql -V)
    sudo apt install timescaledb-2-postgresql-14
    timescaledb-tune --quiet --yes
    Restart PostgreSQL instance
    sudo systemctl restart postgresql
    sudo systemctl status postgresql
    if not enabled yet don't forget to do it otherwise db will not start after reboot
    sudo systemctl enablepostgresql
    to check if it works
    su - postgres
    psql
    CREATE DATABASE testdb;
    Next, change the database to testdb and connect it to the TimescaleDB with the following command:
    \c testdb
    CREATE EXTENSION IF NOT EXISTS timescaledb CASCADE;
    you should get something like
    don't forget to enable remote access etc. see also https://www.linuxcapable.com/how-to-install…n-ubuntu-20-04/
    Noch als Ergänzung - wie man Zabbix von Maria/mysql database auf PostgreSQL migrigriert wird sehr gut in dem Video erklärt:
    und
