Das Mehrgewicht wäre es mir wert. Alternativ käme der SUNON MF40102VX-1Q03C-A99; 40x40x10mm; 24V; 10000U/min; 37dB in Frage. Der schafft fast den gleichen Durchsatz ist aber auch lauter und fast doppelt so teuer. Naja, mal schauen, vielleicht sagt humebeam ja etwas dazu.
Ich gebe die Hoffnung nicht auf.
Heute ist erstmal der Hercules Mod fertig geworden, der geht morgen in den Probedruck.
Wenn der dann brauchbar aussieht werde ich mir Icarus auch nochmal zur Brust nehmen.
Elon Musk hat seine Falcon Heavy, dann sollte ein "Icarus Heavy" auch erlaubt sein
Just get a proper 4010 fan I'm using a high quality Sunon Maglev MF4010V2-A99 in my Icarus builds. It's very quiet, I have to stick my head in the printer to tell if it's on, the specs say 27 dbA but it's really quiet. It's also cheap, you find it on Amazon.de for less than 8 €:
https://www.amazon.de/L%C3%BCfter-40…B/dp/B07CV6VTWB
There is no 4020 fan version planned as it would require a lot of redesign.
Thx for clarification!
Haha just bought 10 there yesterday for testing and if good I will use them for future build. The Winsins etc. are pretty loud (ok they might have some more airflow as well)
Not finally build yet (no inserts...) therefor also no pictures but can be preordered for experienced users as I have still to write the build instruction as well.
Shop one piece of Icarus plastics:
https://www.elektrifiziert.net/shop/index.php…de-icarus-vers/
Danke, geordert.
Grüße
Coming soon. Mosquito and Zodiac x Phaetus BMS mounts for Icarus.
I don't have a Zodiac x Phaetus BMS but it should work. I have a Mosquito clone, I will it print and try the mount.
These options are mostly for those who are curious or perhaps already own one of the hotends.
The mosquito version is compatible with the DIY Hotend from Vonwange, it's a Mosquito clone with a sligthly different heatblock.
The upside is we can source these here in EU and they're considerably cheaper than Dragon.
I bought exactly the same for testing - but never tried - so I would try...
FYI: Vonwange are very active in the Voron Community
I know, love vonwange I bought mine from Mellow before they were all removed (NF-Crazy with Copper heatblock) but it looks identical to vonwanges.
Re: Mosquito clone.
Good news, it fits. A bit more difficult to get the heater and thermocouple in place but no problems.
Bad news. The fan duct needs to be redesigned a little because it hits the heaterblock which is turned 90 degrees compared to Dragon/V6. No idea why they did that. Original Mosquito will be no problem and will work with the normal fan duct but not this. I think I'll just adjust the fan duct a little.
Etwas vom Thema abgekommen, aber immer noch mit der Mod verbunden, da sie sie verbessert. Funktioniert natürlich auch mit Standarddruckern und Hercules oder der Tschad-Version.
QIDI X-Max - Automatische Unterstützung für Flachbandkabel
Ich werde es noch etwas testen und dann bis zum Wochenende hochladen.
Das war nur eine Idee, die ich hatte, ich war verärgert über das Herunterfallen des Kabels, das Stress verursachte, also habe ich das vor ein paar Nächten gemacht und es jetzt getestet. Bisher nur etwa 10 Stunden mit installiertem Gerät gedruckt. Funktioniert wie vorgesehen.
Wie Sie sehen, fährt es automatisch ein.
Externer Inhalt m.youtube.comInhalte von externen Seiten werden ohne Ihre Zustimmung nicht automatisch geladen und angezeigt.Durch die Aktivierung der externen Inhalte erklären Sie sich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt.Einiges mehr hier:
Hallo humebeam,
wäre an der .stl für das Flachbandkabel interessiert. Habe heute feststellen müssen das sich mein Kabel langsam auflöst . Eventuell kann deine Kabelführung helfen den Prozess zu stoppen bzw. zu verlangsamen.
Bist Du mit deinen Tests weitergekommen?
Hat jemand einen Link für mich wo ich eine passendes Ersatzkabel bekommen kann, würde ich mir schon mal auf die Seite legen.
Danke
Kabel habe ich bei Qidi in China über den Support gekauft. Wenn es das irgendwo in der EU gibt fände ich einen Link auch super.
Hello humebeam,
would be interested in the .stl for the ribbon cable. Today I noticed that my cable is slowly dissolving = O. Perhaps your cable routing can help to stop or slow down the process.
Did you get any further with your tests?
If someone has a link for me where I can get a suitable replacement cable, I would put myself on my side.
thanks
Ah yes. There didn't seem to be too much interest for it which I thought was a bit strange. Yes it works great, no more broken cables
I'll upload it tomorrow night If people want to try it.
ich werd´s auf alle Fälle mal testen
Bei Ali habe ich das gefunden
€ 13,48 | QIDI TECH Hohe Qualität Extruder Flache Kabel Für QIDI TECH X-Plus/X-Max 3D Drucker
Yup Danke - das ist quasi Qidi support (ohne den Umweg über mail) Die Versandkosten sind OK, via Mailsupport kostet es meist ~30€ DHL express (was in der Regel deutlich schneller ist)
Anyone know the length of the cable? I may be able to source some at low cost.
Looks like 155cm - at least that is what I measured on my spare one. But not sure if this is a MAX or PLUS.
I also measured my spare cable for the X-Max: 164.5cm
