Qidi Extruder Upgrade Hercules Mod
Danke für das Detail (PTFE ebenfalls in Orange).
Nice touch with the different colours for the PCB cover and dial holder, love it
Moin
FYI: zumindest mal ein Feedback dass die 19.10mm Variante ohne Spiel passt. Warte noch auf das Zweite feedback zum 19.00er. Drucke aber schon mal einen weiteren 19.10 um da vorbereitet zu sein für Shop opening Herkules.
Ole
Second one fits as well. Still some hopefully solvable issues but not related to bearings.
I also changed the mounting instructions to use a Z build volume decrease by one 1cm. the Fast leveling method with a "bunch" of steps seems to be to risky causing a nozzle-bed crash.
Nice to hear it fits
Regarding Z: I need to check by installing a stock carriage and see how it compares but now (since version 1.7) the bearings sit lower by 1 mm and therefore the nozzle 1 mm higher than before so it's possible you don't even have to lower the Z offset by fast leveling and pressing down anymore but I have kept the instructions as is until I know for sure.
The build volume does not need to be reduced, the full build volume is available. We just just set a different z offset value by using fast leveling and it will be stored/saved.
Z-Build volume reduction is only temporarily until you do the first fast leveling. I think it is more secure to go down a cm and then a well visisble steps up while leveling then unkown number down (what is a bunch? - just got feedback that even 50 were not enough) and crash. But please check with you stock - I don't have any stock extruder to check unfortunately.
Ah I see. Well I'll check later. I thought 50 would be enough for sure, that's 2.5 mm. My stock extruders aren't stock anymore, done too many modifications but at least the nozzles and bearings sit where they are supposed to
I added one piece to the shop. Have meanwhile printed several 19.10 pieces. Will assemble some next weekend.
Hallo,
ich bin neu hier und habe bereits erfolgreich meinen neuen X-Plus mit Octoprint + Cam ans Laufen bekommen dank dieser tollen Seiten hier...
Nun interessiere mich für den Herkules Extruder Upgrade.
Ist dort bei der vormontierten Version eigentlich die kleine Platine zum Anschluss des Flach-Kabels dabei (wie auf dem Foto gezeigt) oder muss ich die von dem Original Extruder ausbauen?
Wann sind die Packages wieder verfügbar?
Viele Grüße aus dem Rheinland
mcbyte
Moin mcbyte,
die Platine ist dabei - d.h. man kann auch jederzeit (mit Konfigänderung) wieder auf Original zurück.
Ich bau typischerweise 1-2 pro Woche, das ganze ist aber wegen Kalibrierung der Maße zusammen mit PC etwas ins stocken geraten. Du hast evtl. die vielen Releases von Hume gesehen. Wir sind jetzt aber wohl so weit, dass es passen sollte. Gedruckt habe ich jetzt 4 carrianges da von denen zwei gerade im Bau sind. D.h. vermutlich nächste Woche stelle ich wieder 2 neue ein (d.h. man kann die bestellen und ich baue dann). Hotend ist entweder Phaetus und Trianglelabs - sind beider von der Wertigkeit ähnlich. TL kämpft aber gerade bzgl. Patent mit USA Firma und da gab es Lieferumstellungen die die Beschaffung schwieriger gemacht haben.
Added one piece for sale - change the Hotend option selection to choose between TL and Phaetus.
Note: currently no standard flow TL; but HighFlow TL and Phaetus Standard are there. I increased the baseprice a bit but removed extra cost for HF version to ease the selection process.
Always sold out
Yeah - You will get your share as soon as shipped Just got 2 standard TL from china - but the shoplink is again removed. OK the phaetus ones are more or less equal.
No rush You need to up production though
Just kidding.
Planning 1 per week. Maybe two - more will def. not be possible.
But this should be OK according to my experience with the Chad version. Lets get the next bunch of feedbacks. -
I might offer 1.8 degree Cool Power Steppers as option - any interest?
Here a comparison of technical data. Left LDO (1.8), right Trianglelabs Stepper (0.9). The Zaribo has a connector where the LDO general one has fixed cables and is named ASR instead of ASC at the end (at least that's my guess as other then that they look identical).
Main difference next to steps per rotation is less current and higher torque. Due the the BMG gear the higher precision of an 0.9Stepper might be not that important.
If there is interest I will order and do some testing with them. Disadvantage the LDO is bigger and bit heavier. Need to check the clearance to the front of the enclosure as well.
