Almost certain I-Mate will work as well but not confirmed.
Qidi Extruder Upgrade Hercules Mod
Olaf Krause check PM, updated version posted (was over 5 MB so couldn't attach here).
Got it - increased max attachment here to 10MB for registered users
Files updated on Thingiverse.
grummel - zwei Druckfehler bis ich gemerkt habe, dass der Partlüfter defekt ist - mist Billigkram (WINSIN)
Jetzt hab ich aber wieder Pech an den Hacken - Düse bei 90% des Druckes verstopft. Naja um die Passung zu testen reicht es - stay positiv - keine Lust mehr heute
Morgen geht es weiter.
But now I have bad luck again - nozzle clogged at 90% of the pressure. Well, to test the fit it is enough - stay positive - no more desire today
Tomorrow it goes on.
Ouch I have a 1.7 (b) print of the 19.10 mm version running, will test it in the morning. ABS print though.
Funny translation: of the pressure Let us know how it fits. I will check fit as well tomorrow morning.
Test with single bearing works OK - but this was the case with the others as well.
Update on fit: then 1.7b I was able to mount with moderate force - as with the old versions. It sits also tight on the bearing. Now fixing the printer and print a full piece hopefully. I assume I need to change the gears soon as it was grinding the gears a lot.
Nice! My purple ABS printed beautifully, not tested in the machine yet, wife and kids are sleeping
I'll use it for updating my assembly guide today so lots of pics to take.
I feel a little bad
You used the 1.7b 19.10 version?
Yeah for this build. Sits pretty good. My bearings are a tiny bit smaller than specs, measured them again to be sure and got around 18.98. The 19.15 version would be good too but 19.05 would probably be too tight.
I have set 19.10 to be the "normal" size, it should fit pretty much all builds unless the bearings are tiny. Even so it will fit better now that the fan duct sits flush with the bearings so it will also keep them secure.
Keep in mind the bearings clearance for the Chad version is 19.00 or a tiny bit less actually and no issues for people fitting that. But its design is more forgiving and not as firm as it doesn't "grab" the bearings like Hercules does, also the carriage itself is flexible.
Krass
Jetzt habe ich 2x V1.7b 19.10 gedruckt und nun noch ein 19.00. Dann baue ich die um und verschicke an wartende Kunden zum Test. Wenn der positiv ausgeht kommt die Serie.
nur kurzes Update: Umbau läuft - sollten morgen raus gehen.
