I may just make two versions, one normal like the current and one with tighter clearances.
It comes down to individual slicer settings (flow etc), which filament was used etc, it's impossible to make a version with 100% perfect fitment for all.
Hmm OK - but maintaining two versions is a bit cumbersome - but yepp - lets do and wait for more feedback. I will stick to the slighty wider version printed in PC. Depending on feedback you can decide later which will be main thread.
It's probably just that one print I did, I'm not a PC pro
I also think it's best with a single version. We'll stick to the current version, if there is feedback of it being loose I'll offer a tighter version but if not we'll stick to this.
Herkules builds started (based on official 1.6) Step 1 - stepper motors prep. Not sure which is the better option longer cables - motor looking to the other side or as below with the short version. Decides for the short version for the time being.
humebeam did you think about a cable ties bracket below the PCB or similar for even better cable management?
Looking good!
I think that version in the picture is the best, that's how mine is routed currently. No need for a cable tie IMO. Could also do a little longer cable length and pull it under the PCB holder the same way the other cables are secured.
But you can also run a longer cable around and below the extruder the same way the heater and thermocouples are routed, a little less space though. This is from my assembly guide:
humebeam is it mandatory to shorten the BMG lever for the x-PLus as well? with the chad version only the MAX needed the shorter one - same for yours?
Second build - third one ready for prep in the background
The extruder position is identical to Chad's because I wanted cross-design compatibility for fan ducts and so on so if the full size handle fits Chad's X-Plus, it should also fit this.
Got your donation for the builds, much appreciated.
I am still struggling with the FAN Ducts challenge to print them clean in PC. Was experimenting with Layer Width for external perimeters. Default would by 0.44 but need to go down to 0.29 to get a clean sliced object
Left 0.32mm, right 0.44mm creating tiny holes
~0.32mm creates a big hole left even if fine right, 0.29mm looks OK everywhere - never printed with that thin perimeter yet
Might be very slicer depending - the above was a Prusa 2.3
humebeam which setting did you use for the fan ducts?
Alles anzeigenI am still struggling with the FAN Ducts challenge to print them clean in PC. Was experimenting with Layer Width for external perimeters. Default would by 0.44 but need to go down to 0.29 to get a clean sliced object
~0.3mm creates a big hole left, 0.29mm looks OK everywhere - never printed with that thin perimeter yet
I'm using a line width of 0.40 mm.
Could you point out on a larger picture where the issues are? I think I may need to create a bit thicker walls.
Alright thanks buddy I'll do some adjustments ASAP to improve printability, should be by tonight at the latest.
Yup. Version 1.3 posted, should be at least two walls everywhere with a 0.4 mm nozzle with a line width up to 0.48 mm, at least that's what my S3D preview showed:
https://www.thingiverse.com/thing:4780615
I'll check my other slicers tonight but should be good.
Look good with 0.4mm Width - maybe check the STL - Prusa gave an STL error (that can be auto repaired) -
Zitat von Prusatwo facets reversed
Alright checking tonight, cheers.
Fixed version uploaded, thanks for the notice
Some pictures of the current build now with 1.3 FAN Duct it self. Now it should be ready for first shipping.
Thanks to humebeam for all those improvements on the fly
FAN Duct still bit too much stringing but OK I spent now two spools on PC test prints....
Lets see what we still improve after first customer feedbacks
Looks awesome
