Hello,
this time in english as there might be also people outside German speaking countries interested in this...
Intro
And an important disclaimer - especially if you are not yet expert in in to handle and modify a 3D printer:
- Wichtig: Wir sind nicht verantwortlich for irgendwelche Schäden. Bitte nutzt die Anleitung und die Upgradeteile auf Euer Risiko. Wir verkaufen hier kein fertiges Produkt, sondern die Teile für Euch zusammengestellt und optional zusammengebaut um Euch Aufwand zu ersparen.
- Important: We are not responsible for any damage. Use responsibly and at your own risk. We do not sell a finished product here, but the parts put together for you and optionally assembled to save you effort.
As the Qidi X-Plus and X-Max is regulalry suffereing a clogged nozzle/ the extruder gears are no longer able to transport the filament there are several modifications out there to improve this. On top Qidi uses propriatary hardware which could also be replaced by more "standard" one for easy replace and maintenance so becoming more independent from Qidi sourcing. AS such a mod is somehow challenging to source (parts) and Polycarbonate is not the easiest material to print we decided to offer this modification as a prebuild service. So here we go with the manual how to assemble on your individual printer.
The process below takes typically 30min but is highly depending on your experience using 3D printers and changing config using gcode files. Basic knowledge like using a text editor is mandatory.
Tipp for navigation within this page:
- Use the content index on the right side and for links towards subtopics like taking a backup use the browser function "open in new tab or window" (via right mouse button over the respective link) so you can easily jump between this page and the subchapters.
- For translation use the chrome browser translation feature or for Firefox install a translation plugin. This works pretty well.
Parts delivered to you
The assembly consists out of three main parts:
- Carriage (top part) with all main extrusion relevant pieces mounted - details see here
- Fan-Duct for part cooling - you have to temporarirly remove the fan-duct for the mounting process
- Belt Clip
Top Carriage left and Fan-Duct mid & belt-clip right picture
Extras you might get:
- Spare Fan-Duct
- Dialindicator Holder
Tools and preparations
Tools needed
- Allen keys
- A flat file to adapt belt clip
- USB SD card (should be included with your printer)
- Notepad ++ or similar editor
- Loctite (optional - if you want to secure your screws)
- Heattransfer paste for high temperature use (optional if you want to improve heattransfer between heatblock and nozzle)
Preparations
Backup of your current printer config
See here for detailed intructions
Next, remove the original QIDI extruder and carriage. To do so
- Power down your printer and disconnnect your power cable!
- Remove the screw from the top cover
- Remove the cover
- Unplug the ribbon cable
- Enscrew the extruder from below with the two screws (and possibly fan duct if you have one)
- Lift out the extruder
- Remove two screws holding the belt plate
- Lift over belt then pull off the whole carriage carefully but firmly, it can sit very tight on the bearings
DONE - with preparations and disassembly. Now we build it up again using the mod.
Herkules Assembly
Mount the carriage
Starting point is a
- clean, powered down Qidi and
- the stock extruder removed.
- Fan-Duct removed from the Herkules mod
So it should looks like:
Now place the mod onto the bearings and ensure that they are in parallel to the carriage and slided into the slot a bit already.
Now press firmly on both bearing of one side with your two thumbs while holding the carriage with your index fingers into the carriage.
Note: here I used only one hand as the other one hold the camera
You HAVE to do in in pairs or all four together, if not it is very likely that the bearing will be canted. To do all four at once you can press with one hand from top onto the stepper and extruder (dont press the stepper board!) while at the same time you hold/push up with the same force the bearings/bars/rails. If you don't hold the bars you might slighty deform them. So you should consider Mr. Newtons laws.
Picture source: https://www.thingiverse.com/thing:4780615
After the carriage should plop/snag into place it looks like:
Carriage mounted
The bearing should sit tight into the housing. If the Fan-Duct is mounted there should be still a small
gab between bearing and FAN-Duct.
The carriage should slide on the rails like shown here:
Note: my bearings are old and noisy...
Insert the belt clip
Now move the carriage to the outmost left side on the rails. Ensure that the belt is placed exactly over the teeth of the carriage (teeth into gap). Then gently slide the belt-cip in.
Depending on belt thickness you might need a little force. If it is really too tight you can sand the bottom of the belt clip a little bit.
Picture from https://www.thingiverse.com/thing:4780615
Please double check if the belt sits correct, as in above picture and is not half of the holder.
Mount the Fan-Duct
That is fairly simple, just take the for screws and scree it from the bottom onto the carriage. Nothing special to be considered other than that the air flow channel of course needs to sit at the back where the opening in the carriage is.
Important: Check tight fit
At this point please check the bearing fit on tolerances BEFORE you continue. As we got some reports of smaller bearings/not tight enough fit please test the Carriage and ensure that you can not move it up&down like shown in this video:
That the bearings can be rolled a bit is OK but the carriage should not be able to move up and down.
If this happens a smaller version will be provided - please contact us.
Insert Ribbon cable
Inserted ribbon cable
this step is a bit cumbersome/tricky to manage the cable through the holder into the connector. Please stay patient don't become agressive maybe some deep breath helps and try it again - it can be done... I know you can make it - as even I did it. Don't bend the cable too much!
Firmware/config changes
For the following steps the printer needs to be powered on again - this assumes all steps above where succesful! Of not or questions please consult me via the conversation button in the right top corner of this forum:
Please check if the temperatur of the heatblock is reported correctly
Note: the picture shows Celsius, typically the sensor is reporting ~5C more than real. But this does not matter for 3D printing that much as you anyway need to dial in your target temp based on a heat tower per material your print. In case it shows 1077C the connectors are not sitting properly - please check cabling.
Please take care of your Extruder Gear/Stepper degree setup and adapt the e-steps acordingly - see also Extruder Kalibration Defaulvalues. The below examples are for an 0.9degree stepper, which I use per default if nothing else is ordered. E.g. for the 1.8 Stepper like the "robust version" BMG 1.8: M8011 S0.002388919; would be the right value.
X-Max Specific
Use this only on X-Max (X-Plus is below)
M8002 I1;X motor direction
M8005 I1;Stepper motor direction
M8011 S0.00119446;E-steps
M8024 I290;X Maximum stroke
M8025 I240;Y Maximum stroke
M8026 I290;bed height change
M8500;Save changes
Put the code into a .gcode file on your USB drive and print the gcode file (as for the backup command above). The procedure is the same as for the backup. You can doublecheck if the values are correctly stored as setting if you take another config backup (please choose a different filename as before) and search for the M codes (like M8026) you should see exactly the values given above. If not stop the procedure and recheck the config change / contact me.
Note: The maximum stroke values are for security reasons 1cm smaller than they could be. You can adapt later to increase build volume again. E.g.
but be careful with this.
X-Plus Specific
Use this only on the X-Plus (X-Max is above)
M8024 I260;X Maximum stroke
M8025 I190;Y Maximum stroke
M8026 I190;bed height change
M8500;Save changes
Put the code into a .gcode file place on your USB drive and print the gcode file (as for the backup command above).
Note: The maximum stroke values are for security reasons 1cm smaller than they could be. You can adapt later to increase build volume again. Eg.
But be careful with this. The Z (bed) value will be corrected doing the first bed leveling. Be careful there as well. Best have your hand on the powerbutton when you do first movements being prepared for emergency stops.
Movement check
Move your extruder manual and slowly to the middle like:
If you now move the tool head via tools on the touchscreen it should look like:
In case the extruder moves to the right even if you pressed the left button the direction setting above did not work. Please check again if you executed the steps correctly.
Now do a standard fast leveling - to calibrate the Z-Height. Hold your finger on the poweroff button and be ready to power down in case the nozzle moves into the bed. This should not happen except you forgot to move down the bed as described above.
Bed Leveling positions
Since the Extruder has a different dimension the nozzle position might be no longer on the right spot above the bed where you would like them to be. This is depending on your print sheet. To adjust the position please follow the instruction in "Bed Leveling settings - How to move bedleveling spot to different locations". It is just four lines of gcode with new positions that needs to be sent to the printer.
First usage temp
As I typically test the function using cleaning filament (transparent nylon), please ensure that the nozzle temp for first loading of filament is >=240C until your chosen filament is extruded for some cm and the cleaning filament is fully removed.
Tuning and optimizations
As further steps you should do some further calibrations like:
- PID Tuning - tunes the algorithm to heat up your nozzle and to keep nozzle temp stable - as we replaced heater and fans this should really be done!
- Build Volume optimization - above we reduce the max volume, here how to increase it again
- Extruder Calibration - Howo to calibrate the amount of filament flowing out per stepper rotation.
Spareparts/Ersatzteile
I have them typically also on stock - so if not in the shop yet you might ask. At least shipping within Germany should be much faster as from China.
Here for Trianglelabs:
- TL Dragon Heatbreak
- TL Dragon Heatsink
- TL Dragon Heatblock
- TL Plated Copper Nozzles
- TL Dragon Screw Set
- TL Dragon Adapter
- TL Standard Nozzles
- TL Hardend Steel Nozzles
- TL Steppermotor
- TL Steppergear
- TL Heatelement 50W
- TL BMG v2 Geardrive
- TL BMG Gearset
For Phaetus sparsparts please check google or their reseller website - I might also put some spareparts into the shop here later this year.
Fans:
- Winsin Part Fan 50mm
- TL Part Fan 50mm
- Winsin 40x40x10 HB Fan
- Sunon 40x40x10 HB Fan
- TL 40x40x10 HB Fan
- Sunon 40x40x20 HB Fan
- 40x40 Lüftergitter
Further important notes
- The nozzle might rattled lose while transport - so please retighten it with 1.8Nm torque - ideally when warm
- Check all screws if still tight - you might secure them with Loctite if you want, otherwise add the check to your maintenance procedure of your printer (anyway needed)
- In case you want to clean the nozzle with a brush please ensure that you do not not shorten the heat element. According to support group experience this will destroy the mainboard. Heat up the nozzle switch off printer and only after display is off as well start the cleaning process.
- Heatblock/Nozzle heat transition: you can improve heattransition between heatblock and nozzle if you put a bit of thermal paste on the nozzle thread. Be careful with this in case you are going up to high temp like >280C as not all thermal pastes are able to handle those temps. You might bake nozzle and heatblock together. Note: Per default Qidi does not allow temps >300C.
- DialIndicator-holder: sometimes a just put some holders for free into the boxes - those are not sanded yet - to fit them in you need to sand and drill until it fits to your holder and carriage.
- Filament change: If possible don't use the Qidi change procedure which tries to push forward the filament speedily and then ejects the filament. This creates unneded stress on the drive and does not work very well with Dragon hotends. Instead just let the filament run through the drive added your new filament on top so that it smoothly replaces the old one. Let it run until the filament extruded is the new one only.
Kommentare 17
