Step 1: Install samba client stuff on the PI
sudo apt-get install samba-common smbclient samba-common-bin smbclient cifs-utils
sudo mkdir /mnt/samba_backup
sudo mount -t cifs //<your-server>/backup /mnt/samba_backup -o user=user,pass=password,dom=domain
to remove mount just use umount /mnt/samba_server
to mount permanently add somthing like
to your /etc/fstab. yourcredentialfile should look like
Step 2: Check if access works like
In my case the it looks like
pi@octovoron:~ $ ls -lart /mnt/samba_backup/IOTBackup/
total 0
drwxr-xr-x 2 root root 0 Mar 13 08:55 ..
drwxr-xr-x 2 root root 0 Mar 13 08:56 PiHoles
drwxr-xr-x 2 root root 0 Mar 13 08:56 OctoPi
drwxr-xr-x 2 root root 0 Mar 13 08:56 TeslaLogger
drwxr-xr-x 2 root root 0 Mar 13 08:57 DMZ_Banana
drwxr-xr-x 2 root root 0 Mar 13 08:57 Cameras
drwxr-xr-x 2 root root 0 Mar 13 08:57 .
Step 3: Use DD to take the backup
check fstab for your shares if you forgot what you did in step 2
pi@octovoron:~ $ cat /etc/fstab
#proc /proc proc defaults 0 0
PARTUUID=562352cc-01 /boot vfat defaults 0 2
PARTUUID=562352cc-02 / ext4 defaults,noatime 0 1
//server/backup /mnt/samba_backup cifs credentials=/home/pi/.smbcredentials 0 0
and lsblk for your drives
pi@octovoron:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 476.7G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 476.5G 0 part /
then you can execute something like
sudo dd if=/dev/mmcblk0p2 of=/mnt/samba_backup/IOTBackup/OctoPi/octovoron_root_2021_03_13.img bs=1M
Depending on the size it might take a while!
